Matthias
5 months agoError with PDN Tool 2.0 for Cyclone V
Hello, I'm trying to use the PDN Tool 2.0, version 16, build 04.27, for Cyclone V. After starting the tool, I keep getting the following error message: Runtime error 53 File not found: 28nm_pdn_1...
- 4 months ago
Hello Farabi,
Thank you for your reply.
I've solved my problem in the meantime.
I copied the missing DLL file (28nm_pdn_16.0_hid_04_27_32bit.dll) from the original directory
C:\Users\xxxx\AppData\Local\Temp\PDN_Tool\28nm\16.0\04.27\ to the directory
C:\Windows\SysWOW64\
Now it works.
Regards, Matthias
Matthias
4 months agoHello Farabi,
Now it works.
Regards, Matthias
Farabi_Altera
4 months agoHello Matthias,
Thanks for sharing workaround. I will put this workaround in our KDB(Knowledge Database).
regards,
Farabi
