16 years agoError: Too many output and bidirectional pins in I/O bank 2
Hi, everybody. I am designing a new product on EP2C5Q208C8. In the design ,I use DDR sdram controller. so ,there are many sstl2 standard pins. But, I encounter the following error. how to ru...
16 years agojakobjones is basically right, there are however two cases, where the problem may simply overcome:
- The error occurs, because you missed to specify correct output_enable_groups for the DQ and DQS pins. This may happen, if you didn't import all files generated by DDR controller Megawizard - The conflicting pins are fully static in normal operation and IO distance rules check can be disabled by specifying a toogle rate of 0 MHz.
