14 years agoError "not declared" but defined with `define?
Hello, I would very much appreciate some help with this puzzling error.
(Just to be clear, I know this simple example here won't produce anything useful. Its just to illustrate my problem. Thanks) error (10161): verilog hdl error at def.v(12): object "high" is not declared This is the code in def.v:`define HIGH 1'h1
`define LOW 1'h0
module def (clk, q);
input clk;
output q;
wire clk;
reg q;
always @ (posedge clk)
begin
q <=# 1 HIGH;
end
endmodule
Thanks!2 Replies
Thank you Cris72! That is a great help :)
You missed a `
This way should work: q <=# 1 `HIGH;
