Error in configurating
Hi ,
While i am checking the following command in nios 5 i am getting the following error what is the meaning of it?
nb: my fpga is agilex AGFB012R24B2I3E
command is quartus_pgm -c 1 -m jtag -o "ei;examine.fuse;AGFB012R24B2I3E
error is,
Error (18952): Error status: Device does not accept configuration request
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Apr 25 12:31:03 2023
Error: Quartus Prime Programmer was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 1123 megabytes
Error: Processing ended: Tue Apr 25 12:31:03 2023
Error: Elapsed time: 00:00:22
Error: System process ID: 208
where i can find this error id details?
- KellyJialin_Goh
Thank you.
Kelly Jialin, GOH
- KellyJialin_Goh
Any updates or feedback from you end? Did you managed to find a workaround with the suggestion I provided?
Hope to hear from you.
Thank you.
Kelly
- KellyJialin_Goh
Thank you.
Kelly
- KellyJialin_Goh
Greetings and welcome to Intel's forum.
Note that you'll need to specify the command for correct cable number (with c <cable_number>) if you have more than one cable connected to your machine.
You may try to power cycle your board again to see if this issue still appears.
May I also know the Quartus version that you are using with the Agilex FPGA that you have?
Hope to hear on your feedback. Thank you.
Kelly
