kalidas
3 years agoError in configurating
Hi ,
While i am checking the following command in nios 5 i am getting the following error what is the meaning of it?
nb: my fpga is agilex AGFB012R24B2I3E
command is quartus_pgm -c 1 -m jtag...
KellyJialin_Goh
3 years agoHi,
Greetings and welcome to Intel's forum.
Note that you'll need to specify the command for correct cable number (with c <cable_number>) if you have more than one cable connected to your machine.
You may try to power cycle your board again to see if this issue still appears.
May I also know the Quartus version that you are using with the Agilex FPGA that you have?
Hope to hear on your feedback. Thank you.
Kelly
