17 years agoError by compiling Superloop SimpleSocketServer
I patched the simple socket server into a superloop application under 9.0SP2. "building_3c120_superloop_simple_socket_server_plu s.pdf". The patch finished successfully http://www.alteraforum.com/ima...
16 years agoI got the similar problems as yours, but my trial is simple socket server. When built, several error appear, they are unresolved inlcusion :alt_dev_inich.h
not define the ALT_INICHE that showing error and others I solved by adding some paths. How to define ALT_INICHE since I have already select it in BSP editor? Please tell me if you know.
