11 years agoError 170084 ADC & PLL
Given:
Quartus 14.1.1 build190 BeMicro Max 10 10M08DAF484 System clock on N14 Error (170084): Can't route signal "ADC06:inst|ADC06_altpll_0:altpll_0|ADC06_altpll_0_altpll_5q22:sd1|wire_pll7_clk[0]" to atom "ADC06:inst|ADC06_ADC:adc|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance" ADC.qip is the only file in the project and it consists of Qsys IP "Altera Modular ADC core, Avalon ALTPLL and JTAG to Avalon Master Bridge. I am having trouble compiling a the project using system clock on N14. If I compile the project on Clock pin N9 then compilation will complete without errors. What am I doing wrong? Thank you in advance. Mike12 Replies
What doesn't work?
Mike - Altera_Forum
Hi Mikell, it refuse to program after first time.
Here is detail of what happened, http://www.alteraforum.com/forum/showthread.php?t=54757 today I try'd to load a simple counter dividing 50MHz sys input clock then driving some pin to 0 and with 1MHz, 500 & 250KHz toggle. Pin remain as it where open. SOF say success but doesn't work, Flash accept just erase and examine. Thank in advance. Roberto
