16 years agoError 10500
I've finished creating the NIOS II processor system without errors. During integrating the system into Quartus II project I've got an error (10500): VHDL syntax error at CHKMNG_inst.vhd(2) near text ...
16 years ago--Example instantiation for system 'CHKMNG'
CHKMNG_inst : CHKMNG port map( out_port_from_the_ACHK => out_port_from_the_ACHK, out_port_from_the_CTR0HEX => out_port_from_the_CTR0HEX, out_port_from_the_CTR1HEX => out_port_from_the_CTR1HEX, out_port_from_the_CTR2HEX => out_port_from_the_CTR2HEX, out_port_from_the_CTR3HEX => out_port_from_the_CTR3HEX, out_port_from_the_ERR => out_port_from_the_ERR, out_port_from_the_PASS => out_port_from_the_PASS, out_port_from_the_PMARK => out_port_from_the_PMARK, out_port_from_the_RST => out_port_from_the_RST, out_port_from_the_WCHK => out_port_from_the_WCHK, clk_0 => clk_0, in_port_to_the_KEY => in_port_to_the_KEY, in_port_to_the_RSIN => in_port_to_the_RSIN, in_port_to_the_RSVAL => in_port_to_the_RSVAL, reset_n => reset_n );
