12 years agoEPM7064s INPUT/OE/GCLK pins connection while using ISP(JTAG)
At the moment I'm a student at Avans Hogeschool in the Netherlands. I want to use the EPM7064s CPLD for a project. I would like to program it with JTAG. I only have a question about how I need to connect the 4 dedicated INPUT / OE / GCLK / GCLRn pins when I want to use the ISP function with JTAG. Pin 1, 2, 43 and 44 of the EPM7064s, 44-pin PLCC package. For example, do I have to pull those pins up with a resistor? Thanks, Michiel1 Reply
You need to drive them to a valid I/O voltage. To quote a report file:
--- Quote Start --- This pin should be connected to GND. It may also be connected to a valid signal on the board (low, high, or toggling) if that signal is required for a different revision of the design. --- Quote End --- Regards, Alex
