12 years agoEPM7064s INPUT/OE/GCLK pins connection while using ISP(JTAG)
Hello, At the moment I'm a student at Avans Hogeschool in the Netherlands. I want to use the EPM7064s CPLD for a project. I would like to program it with JTAG. I only have a question about...
12 years agoYou need to drive them to a valid I/O voltage. To quote a report file:
--- Quote Start --- This pin should be connected to GND. It may also be connected to a valid signal on the board (low, high, or toggling) if that signal is required for a different revision of the design. --- Quote End --- Regards, Alex
