13 years ago
EPCS selection for Cyclone V
Hi all!
Please help to choose epcs device for configuration 5CEA4U15.
We need minimum size package of EPCS, because we have limited space on board.
    Read the handbook, and find the number of bits in the configuration file. That determines your flash size (without compression). From that you can select a configuration flash.
    The minimum physical package size depends on whether you use Altera's "standard" devices, i.e., SOIC8 or SOIC16, or you use a compatible device. For example, the EPCS devices are re-branded Micron (previously Numonyx) parts; if you read their device identification (opcode 9Fh), the details read back are those of the Micron parts.
    http://www.micron.com/products/nor-flash/serial-nor-flash
    If you click on the M25P tab, these are the "classic" SPI flash devices. If you click on the N25Q tab, these are the EPCQ Quad-SPI flash.
    Spansion S25FL devices can also be used
    http://www.spansion.com/products/serial-flash/pages/spansion%20fl.aspx
    If you click on the technical documents tab and scroll down you will find this app note
    http://www.spansion.com/support/application%20notes/configuring_altera_fpgas_via_spi_flash_an.pdf
    If you look at the data sheets for these devices, you will find many more packaging options.
    Cheers,
    Dave
    Thank's a lot for your answer, Dave!!!
    That's what I need!
    Hello Dave,
    I've looked though all of the Cyclone V manuals and data sheets and am unable to find where the number of config bits is listed. Can anyone please provide a page number?
    I tried to generate a JIC file for the 5CEBA2F17 with a EPCS16, but got an error saying the part was too small, yet a designer who no longer works here designed in the EPCS16 saying it would work.
    --- Quote Start ---
    --- Quote End ---
    They're listed in the data sheet - Table 57. Uncompressed .rbf Sizes for Cyclone V Devices - p54 of the PDF
    http://www.altera.com/literature/hb/cyclone-v/cv_51002.pdf
    --- Quote Start ---
    --- Quote End ---
    The amount of compression possible depends on the complexity of the design; a blinky LED project might compress, but a real-world project might not ...
    Cheers,
    Dave
