13 years agoEPCS selection for Cyclone V
Hi all! Please help to choose epcs device for configuration 5CEA4U15. We need minimum size package of EPCS, because we have limited space on board.
13 years agoRead the handbook, and find the number of bits in the configuration file. That determines your flash size (without compression). From that you can select a configuration flash.
The minimum physical package size depends on whether you use Altera's "standard" devices, i.e., SOIC8 or SOIC16, or you use a compatible device. For example, the EPCS devices are re-branded Micron (previously Numonyx) parts; if you read their device identification (opcode 9Fh), the details read back are those of the Micron parts. http://www.micron.com/products/nor-flash/serial-nor-flash If you click on the M25P tab, these are the "classic" SPI flash devices. If you click on the N25Q tab, these are the EPCQ Quad-SPI flash. Spansion S25FL devices can also be used http://www.spansion.com/products/serial-flash/pages/spansion%20fl.aspx If you click on the technical documents tab and scroll down you will find this app note http://www.spansion.com/support/application%20notes/configuring_altera_fpgas_via_spi_flash_an.pdf If you look at the data sheets for these devices, you will find many more packaging options. Cheers, Dave
