16 years agoepcs controller
I'm trying some informations about EPCS CONTROLLER control word. Inside datasheet doesn't speak about meaning of single bit inside EPCS control words. Somebody knows this bits? I don't understa...
16 years agoThe c4up.v is generated using altera megacore wizard. The rcu.v is an implementation similar to the cyc3 of sopc builder because altera didn't release the source.
So it is the core for sopc builder. You can look at the driver code of cyc3 and do it in a similar way. Beside, if there is still a chance touch the hardware, you would be better to use PS mode to configure the fpga (no need the epcs and remote update as AS mode). - Hippo
