AdrienBouvier
1 year agoEPCQ4A with Quartus 13.0
Hello, I would like to replace the EPCS4SI8N component, which is now obsolete. The EPCQ4ASI8N seems to be the most suitable replacement. However, I have some concerns regarding programming compatib...
sstrell
1 year agoIf you're just using the Quartus Programmer (not doing design), any version of the software would work. You can even just download the Programmer standalone.
- AdrienBouvier1 year ago
Thank you very much for your helpful answer.
I have one more question.
We originally used .pof files to program the EPCS4SI8N.
What I would like to do now is use those same .pof files (originally generated for the EPCS4SI8N with Quartus 13.0) to directly program the EPCQ4ASI8N, without regenerating or converting them.Would it be possible to use these existing .pof files with the Quartus Programmer Standalone to program the EPCQ4ASI8N?
- FvM1 year ago
As far as I see, EPCSQ4A is full compatible with EPCS4, e.g. equal Silicon ID. I expect that .jic generated for EPCS4 will work for EPCSQ4A as well.
