isagani's avatar
isagani
5 years ago
EP3C5E144C7N and EP3C5E144C8N
Please advise difference between EP3C5E144C8N and EP3C5E144C7N?
Can EP3C5E144C7N replace EP3C5E144C8N?
  • Hi @isagani
    Hope you are doing well.
    The following handbook will make you understand what is the difference between EP3C5E144C8N and EP3C5E144C7N Cyclone III devices.
    Cyclone III Device Handbook Volume 1. Chapter 1. Cyclone III Device Family Overview ( Ref. Page 1-12)
    So after looking at the attached image and the handbook you will get that the numbers 7 and 8 in EP3C5E144C8N and EP3C5E144C7N model nos. represents the speed grade of the cyclone III device family.
    So speed grade of EP3C5E144C7N is higher than EP3C5E144C8N.
    Hence EP3C5E144C7N can replace EP3C5E144C8N as both are having the same package types but there will be an increase in speed grade.
    Hope this will resolve your issue.
    Shivam_Shobhit
  • Hello isagani
    Thank you for posting on the Intel️® communities. Requests for FPGA products should be posted on the "FPGAs and Programmable Solutions" section. We will move this thread now.
    David G
    Intel Customer Support Technician
  • Hi @isagani
    Shivam_Shobhit
    • isagani's avatar
      isagani
      Hi Shivam,
      Thank your for the quick response. Can you help me on the speed grade 7 and 8 values?
      • Shivam_Shobhit's avatar
        Shivam_Shobhit
        Hey @isagani
        Hope this helps :
        Intel MAX and Classic devices use the speed grade to indicate the delay in nanoseconds (ns) through a macrocell in the device. For example, a MAX device with a -10 speed grade has a delay of 10 ns through a macrocell. Devices with low-speed grade numbers run faster than devices with high-speed grade numbers.
        Refer: Speed Grades
        Shivam_Shobhit
