EP3C5E144C7N and EP3C5E144C8N
- 5 years ago
Hi @isagani
Hope you are doing well.
The following handbook will make you understand what is the difference between EP3C5E144C8N and EP3C5E144C7N Cyclone III devices.
Cyclone III Device Handbook Volume 1. Chapter 1. Cyclone III Device Family Overview ( Ref. Page 1-12)
So after looking at the attached image and the handbook you will get that the numbers 7 and 8 in EP3C5E144C8N and EP3C5E144C7N model nos. represents the speed grade of the cyclone III device family.
So speed grade of EP3C5E144C7N is higher than EP3C5E144C8N.
Hence EP3C5E144C7N can replace EP3C5E144C8N as both are having the same package types but there will be an increase in speed grade.
Hope this will resolve your issue.
Shivam_Shobhit
Hi @isagani
Shivam_Shobhit
- isagani5 years ago
Hi Shivam,
Thank your for the quick response. Can you help me on the speed grade 7 and 8 values?
- Shivam_Shobhit5 years ago
Hey @isagani
Hope this helps :
Intel MAX and Classic devices use the speed grade to indicate the delay in nanoseconds (ns) through a macrocell in the device. For example, a MAX device with a -10 speed grade has a delay of 10 ns through a macrocell. Devices with low-speed grade numbers run faster than devices with high-speed grade numbers.
Refer: Speed Grades
Shivam_Shobhit
- Anonymous5 years agoNot applicable
@Shivam_Shobhit It is always best to provide the source for a cloned answer.
Doc (not an Intel employee or contractor)
