10 years agoEP2S60F1020 device testing
Hello I am doing functional testing of EP2S60F1020 using JTAGAfter doing power up pins are getting auto assign as per program. BSDL file downloaded from net is not working. Please help. ...
10 years agoDepending on the configuration scheme chosen, the FPGA will always try to configure at power up. If there's a valid configuration image then it will always boot and assign the pins 'as per program'. I assume that's what you refer to.
However, you should always be able to take control of the FPGA, via JTAG. Occasionally BSDL files have faults in them. However, with a mature series, like Stratix II, this shouldn't be the case. Download the BSDL file again. Make sure you take it from the "stratix ii bsdl files (https://www.altera.com/support/support-resources/download/board-layout-test/bsdl/stratix2.html)" page. Cheers, Alex
