16 years agoEP2C5t144C8N pll clock in range...
Hello! Can i drive the pll of this device (EP2C5t144C8N) at 25MHz? The pll is capable to lock with this input freq? tnx!!!
16 years agoYes, the minimum input frequency is 10 MHz. You should check however, if the PLL is able to generate all intended output frequencies with 25 MHz input clock.
