19 years agoEP1C3T100C8N FPGA configuration problem
Hi everybody, In my design I use an EP1C3T100C8N cyclone which gets configured from an EPCS1 serial device. EPCS1 is programmed from an external microcontroller that gets the data stream f...
19 years agoThank you for your answer BD SLS,
I have no JTAG connexion on my board and cannot test EPCS1 programing through JTAG) Here is my wiring: MSEL0=GND MSEL1=GND INIT_DONE left not connected DATA0 (FPGA) <=> DATA (EPCS1) DCLK (FPGA) <=> DCLK (EPCS1) nCS0 (FPGA) <=> nCS (EPCS1) ASDO (FPGA) <=> ASDI (EPCS1) nSTATUS&CONF_DONE tied to 3.3V VCC through 10K resistor. nCE (FPGA) receives a '0' from µC I/O I tried to disconnect nCONFIG from 74HC04 and connect it directly to 3.3V VCC through 10K resistor (to be as the schematics in datasheet), but the problem is the same. Hope I have not omitted some pins involved in configuration, but as per my understranding, the AS mode is selected by grounding MSEL1-MSEL0?? On my board, FPGA's CLK0 pin is constantly fed by a 16MHz 3.3V clock signal. Hope this cannot "disturb" FPGA during configuration process. Whitebird
