dulf
3 years agoEmtpy MAX10 jam-file
Hello, I want to erase a MAX10 10M25SAE144A7G. Do you have a jam file for this? Best regards
lixy
Contributor
3 years agoHi there,
What do you exactly mean to "erase MAX 10"? Do you mean erase the image in CFM (Configuration Flash Memory)?
If you are using Intel Programmer, just put any JAM file matching your device, and select "erase" operation, then "start" operation.
If you are using Jam player or other command lines, normally there's "Erase" command to perform "Erase" to MAX 10.
(Intel Programmer)
Thanks & Regards,
Xiaoyan
