16 years agoEfficient Firmware version control
Dear Gurus, I've have two boards in my system using altera cyclone FPGAs and I want to be able to read the firmware version of each (from the PC controlling the system). The PC can read/write ...
16 years agoIt is pretty easy to use tcl scripts to handle this. View this post:
http://www.alteraforum.com/forum/showthread.php?p=25672#post25672 I think it does a pretty good job explaining how to use them and with reference files. Not listed in that forum post, but what i do currently, is force the version numbers to be stored in a register and set an attribute to that register so that it doesn't get synthesized away. This way you can edit the version number post compilation with the resource property editor, so if you need to up the beta number for a release you don't have to recompile your whole design. Now a days registers are basically free, especially when you are only using an 8-bit version number. Hope this helps, although you have probably already seen it from the sound of your original post. Kevin
