17 years agoed8b10b Encoder/Decoder
Hello!
I have a Stratix II FPGA : EP2S60F672C3N from altera.. i opened on altera literature ug-ed8b10b.pdf file getting started instructions, i folloed all the steps there and finally i got to the last step: Program Device, i open the programmer and i have dec_time_limited.sof/Device: EP2S60F672/Checksum: 00A..... Program/Configure box checked... ready to push Start.. I hit start and in the end i get an Error message i really i dont understand. Info: Successfully loaded and ran Tcl Script File "C:\Documents and Settings\Sony\Bureau\ed8b10b\decoder_constraints.tcl" Info: Started Full Compilation at Thu Nov 20 19:50:42 2008 Paris, Madrid Info: Ended Full Compilation at Thu Nov 20 19:51:48 2008 Paris, Madrid Info: SRAM Object File C:/Documents and Settings/Sony/Bureau/ed8b10b/decoder_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x0079 Info: Started Programmer operation at Thu Nov 20 19:54:46 2008 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x120930DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Thu Nov 20 19:54:51 2008 Error: Can't communicate with device. Device will stop functioning when it reaches its non-tethered mode timeout limit. For about 1second my LED's on my board stop blinking, is Loading the program into the board i get message in Quartus successfully loaded the program into device and then comes back to factory settings.. please help!5 Replies
still no progress in this... :( is my board broken or so? how do i test it and see if all ok, anyway now my warranty has expired too, quartus II license doh :(
There is no library. You have to add the modules decoder_8b10b.v respectively encoder_8b10b.v to your project. encoder_tb.v can be used as a template how to use the modules.
video_signal,
could you halp me a little on how to whit the cookbook? I open the QII select new project give name and then have to select a library, would this be \cookbook\communications directory? thank you for advice. Regards, Alex. - Altera_Forum
hello video_signal!
I will try to use that one too, i have downloaded it once so have to look on it. But i still wonder, QII .sof is time limited to one hour and i canot use it even for a 1 min. - Altera_Forum
HI UltraViolet,
it seems QII generates, time limited sof. so this problem , why dont you use, synthesis cookbook 8b/10, example instead regards, video signal
