14 years agoDSP Senior Project Question
Hey Guys, Im an EE major just starting on my BSEE senior project. It is to create an FPGA based acoustic echo canceller. We have to use a 1024 tap adaptive FIR filter. It is require...
14 years agoI am not clear about the over all purpose of your filter, but if your main filter is meant to be 1024 taps and to be applied to the input stream continuously but in blocks of 128 stages x 8 then you will need to add up all the 8 outputs continuously and divide result by 8 for every single output sample.
