14 years agoDSP Builder for university student
I'd like to have a look/experiment with DSP Builder for my university project but is there any free/web edition version of DSP Builder? or is this strictly licence only?
I'm running Quartus web edition 11.09 Replies
Does the university program include Mexican too?
scucherish, please do not request licenses on the forum. if you are a student try contacting the University Program. if you are a company, contact your distributor and purchase a license
--- Quote Start --- I didn't realise i could get a full Quartus licence! so would this full quartus licence (and DSP Builder as well) be time limited i.e for the length of my course? I wish i knew this before.. i only have a few months left :o --- Quote End --- hi, do you have a license of dsp builder 10.0, if have ,can you send it to me, thanks very much! my email:[email protected] - Altera_Forum
--- Quote Start --- I didn't realise i could get a full Quartus licence! so would this full quartus licence (and DSP Builder as well) be time limited i.e for the length of my course? I wish i knew this before.. i only have a few months left :o --- Quote End --- It is not time limited in any way. You can also request licenses for components like FIR, NCO, etc. The university program is very nice :) Cheers, Dave - Altera_Forum
--- Quote Start --- Given that you need to request a DSP Builder License, you may as well request a full Quartus license at the same time. You can't use any of the high-end DSP devices (Stratix series) without a full license. Use the VM NIC, or make a NIC up and change your VM to use that NIC. I have multiple versions of VirtualBox with older versions of Quartus installed. The only issue I have seen is that under a Windows 7 host, the USB-Blaster cannot be given to the VM. However, it works fine under a Centos 6.2 and WinXP host. Cheers, Dave --- Quote End --- I didn't realise i could get a full Quartus licence! so would this full quartus licence (and DSP Builder as well) be time limited i.e for the length of my course? I wish i knew this before.. i only have a few months left :o - Altera_Forum
--- Quote Start --- I've just read... 'Before you set up licensing for DSP Builder, you must already have the Quartus II software installed on your computer with licensing set up' Will i be ok with just a web edition licence type? --- Quote End --- Given that you need to request a DSP Builder License, you may as well request a full Quartus license at the same time. You can't use any of the high-end DSP devices (Stratix series) without a full license. --- Quote Start --- Also, the licence request asks for a my NIC address. I am running a virtual machine on my mac so which do i give? is this just for the download or is the licence tethered to the NIC address? --- Quote End --- Use the VM NIC, or make a NIC up and change your VM to use that NIC. I have multiple versions of VirtualBox with older versions of Quartus installed. The only issue I have seen is that under a Windows 7 host, the USB-Blaster cannot be given to the VM. However, it works fine under a Centos 6.2 and WinXP host. Cheers, Dave - Altera_Forum
you can use DSP Builder with QII Web Edition
http://www.altera.com/support/kdb/solutions/rd07262004_7122.html the NIC ID should be that of the Virtual Machine where the software will be running - Altera_Forum
Thanks Dave,
I've just read... 'Before you set up licensing for DSP Builder, you must already have the Quartus II software installed on your computer with licensing set up' Will i be ok with just a web edition licence type? Also, the licence request asks for a my NIC address. I am running a virtual machine on my mac so which do i give? is this just for the download or is the licence tethered to the NIC address? - Altera_Forum
Have your professor join the Altera University program and then he can request a Quartus II full-edition license.
http://www.altera.com/education/univ/unv-index.html https://www.altera.com/education/univ/enroll_form/unv-license_request.jsp Cheers, Dave
