14 years agoDSP Builder for university student
I'd like to have a look/experiment with DSP Builder for my university project but is there any free/web edition version of DSP Builder? or is this strictly licence only? I'm running Quartus web...
14 years ago --- Quote Start --- I've just read... 'Before you set up licensing for DSP Builder, you must already have the Quartus II software installed on your computer with licensing set up' Will i be ok with just a web edition licence type? --- Quote End --- Given that you need to request a DSP Builder License, you may as well request a full Quartus license at the same time. You can't use any of the high-end DSP devices (Stratix series) without a full license. --- Quote Start --- Also, the licence request asks for a my NIC address. I am running a virtual machine on my mac so which do i give? is this just for the download or is the licence tethered to the NIC address? --- Quote End --- Use the VM NIC, or make a NIC up and change your VM to use that NIC. I have multiple versions of VirtualBox with older versions of Quartus installed. The only issue I have seen is that under a Windows 7 host, the USB-Blaster cannot be given to the VM. However, it works fine under a Centos 6.2 and WinXP host. Cheers, Dave
