16 years ago
DQS Pin Assignment Problem in EP4SGX530 FPGA
I am doing the Pin Planning and analysis for my DDR3C pin assignment in Altera EP4SGX530HH35C2ES FPGA ( 1152 Package). I am seeing following error message while doing the I/O Check in the Pin Planner tool.
Error: Bidirectional pin rxd_ddr3_dqs[0] with a pseudo-differential I/O standard must use the output enable control signal on the output buffer
Followings are my qsf file content for this : # ######################### Just for convenience, I am showing only one dqs pin assignemnt.
set_location_assignment PIN_AM10 -to rxd_ddr3_dqs_n[0]
set_location_assignment PIN_AL10 -to rxd_ddr3_dqs[0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.5-V SSTL CLASS I" -to rxd_ddr3_dqs[0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.5-V SSTL CLASS I" -to rxd_ddr3_dqs_n[0]
set_instance_assignment -name OUTPUT_TERMINATION "SERIES 50 OHM WITH CALIBRATION" -to rxd_ddr3_dqs[0]
set_instance_assignment -name OUTPUT_TERMINATION "SERIES 50 OHM WITH CALIBRATION" -to rxd_ddr3_dqs_n[0]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 1 -to rxd_ddr3_dqs[0]
set_instance_assignment -name OUTPUT_ENABLE_GROUP 1 -to rxd_ddr3_dqs_n[0]
I have used DQS for x4 for 1152. Same pin mapping corresponding to F1517 package is passing in the I/O check.
I am not able to fix this issue . I tried all the related option value for this pin in the I/O assignment Editor, but still I/O check is failing. Can you Please suggest any solution for this.
Rakesh
    Hi
    I have the same problem in my Arria II Gx Development Kit when I try to build a Qsys system to access a DDR3.
    Error (176183): Bidirectional pin ddr3_dqs with a pseudo-differential I/O standard must use the output enable control signal on the output buffer
    I have run the tcl file for pin assignment and see the following text in my qsf file.
    set_instance_assignment -name OUTPUT_ENABLE_GROUP 849089556 -to ddr3_dq
    set_instance_assignment -name OUTPUT_TERMINATION "SERIES 50 OHM WITH CALIBRATION" -to ddr3_dq
    set_instance_assignment -name MEM_INTERFACE_DELAY_CHAIN_CONFIG FLEXIBLE_TIMING -to ddr3_dq
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_dqs -to ddr3_dq
    Does anyone know how to solve this problem?
    Note sure if this helps but I seem to have a whole series of:
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[64]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[65]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[66]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[67]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[68]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[69]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[70]
    set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[71]
    set_instance_assignment -name DQSB_DQS_PAIR ON -from ddr3_rdimm_a_dqsn[8] -to ddr3_rdimm_a_dqs[8]
    that I am going to go look for more info on.
