16 years agoDQS Pin Assignment Problem in EP4SGX530 FPGA
Hi, I am doing the Pin Planning and analysis for my DDR3C pin assignment in Altera EP4SGX530HH35C2ES FPGA ( 1152 Package). I am seeing following error message while doing the I/O Check in the Pin ...
16 years agoNote sure if this helps but I seem to have a whole series of:
set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[64] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[65] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[66] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[67] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[68] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[69] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[70] set_instance_assignment -name DQ_GROUP 9 -from ddr3_rdimm_a_dqs[8] -to ddr3_rdimm_a_dq[71] set_instance_assignment -name DQSB_DQS_PAIR ON -from ddr3_rdimm_a_dqsn[8] -to ddr3_rdimm_a_dqs[8] that I am going to go look for more info on.
