PascalPolygon
5 years agoDP to MIPI
Hello guys,
Does intel offer an FPGA that supports DP RX and MIPI DSI TX?
If yes, does the FPGA have a D-PHY bank or is it implementing D-PHY through external resistors?
Lastly, are there any ...
Deshi_Intel
5 years agoHi Pascal,
Sure, I can answer few more questions for you.
just FYI... Intel support structure is on a case by case basic. That's why we always encourage customer to file new case for new enquiry.
Anyway, now to your questions
- I am not familiar with MIPI implementation as I explained to you earlier it's not direct support from Intel. Are you referring to IO pin count or transceiver pin count here ?
- Cyclone V FPGA is offer in many different package with different pin count support. You can checkout more from below Cyclone V ordering code doc
- For the resource utilization on DP MST (2 channel)
- I would say the resource consumption should be between SST and MST (4 channel) but you will need to compile the DP IP in Quartus to checkout the detail
dlim
PascalPolygon
5 years agoThanks for the reply, I have more questions about the cyclone V and MIPI. I'll post a new question about those.
Pascal.
