fgfasfafgfdhagdszfea
4 years agoDoes the Cyclone 10 GX have a hard-reset pin?
Most microcontrollers have some kind hard-reset pin, for example nRST. Basically if you pull the pin low, the device completely resets.
This pin is often used for some kind of external POR or push...
AqidAyman_Altera
4 years agoHello,
Alright, I will take note on that. If in future you would like to use the hard reset pin, I would say the nCONFIG pin is the most accurate pin for you. It is a dedicated configuration control input pin where pulling this pin low during user mode causes the FPGA to lose its configuration data, enter a reset state, and tri-state all I/O pins. Returning this pin to a logic high level initiates reconfiguration.
Aqid Ayman
