fgfasfafgfdhagdszfea
4 years agoDoes the Cyclone 10 GX have a hard-reset pin?
Most microcontrollers have some kind hard-reset pin, for example nRST. Basically if you pull the pin low, the device completely resets.
This pin is often used for some kind of external POR or push...
AqidAyman_Altera
4 years agoHi,
How are you? I just drop by to check with you on my latest comment. Do you have any update on that?
Aqid Ayman
- fgfasfafgfdhagdszfea4 years ago
Thanks for following up.
I was able to make some changes in the surrounding schematic making it so that I wouldn't need this feature.
I was thinking complete device reset, so that it would have to read its configuration all over and everything. I did see the nCONFIG pin which seems like it might do what I wanted, but the documentation seems to indicate the use is if you need to load a different configuration into the device, rather than the intention being a complete device reset.
