RZhen11's avatar
RZhen11
3 years ago
Does Quartus 20.1 std support VHDL 2008 vector aggregation?
I have something like the following:
signal_a(7 downto 0) <= (3 downto 0 => "0001", others => '1');
I got error:
Error (10515): VHDL type mismatch error at ***.vhd(###): std_ulogic type does not match string literal
Please comment
  • I believe you are correct - Quartus Standard does not support aggregates for VHDL 2008 due to its limited language support. The following list is the closest I could find of VHDL 2008 features that Quartus Standard supports, prior to the release of Quartus Pro version:
    https://www.intel.com/content/www/us/en/programmable/quartushelp/16.0/index.htm#hdl/vhdl/vhdl_list_2008_vhdl_support.htm
    I have try to run below code (Fail in Standard but Pass in Pro):
    library ieee;
    use ieee.std_logic_1164.all;
    entity Example is
    port (
    clk : in std_logic;
    reset : in std_logic;
    out_data : out std_logic_vector(7 downto 0)
    end entity Example;
    architecture Behavioral of Example is
    signal signal_a : std_logic_vector(7 downto 0) := (others => '1');
    begin
    process (clk, reset)
    begin
    if reset = '1' then
    -- reset the signal to the initial value
    signal_a <= (3 downto 0 => "0001", others => '1');
    elsif rising_edge(clk) then
    -- do some processing using the signal
    out_data <= signal_a;
    end if;
    end process;
    end architecture Behavioral;
    Richard Tan
    p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
  • Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Thank you and have a great day!
    Richard Tan
    library ieee;
    entity Example is
    port (
    clk : in std_logic;
    end entity Example;
    begin
    begin
    if reset = '1' then
    end if;
    end process;
    Richard Tan
