18 years ago
DMA doesn't write due to high write waitrequest
I have an SOPC builder system that implements the design sample in ug_pci_express.pdf but with a different BAR setup and address bases. I've modified the testbench to reflect this, however I'm running into a weird issue:
In dma_ctrl, the commands are received for the dma transfer and the read starts (successfully, getting the data). However, the write_waitrequest is always asserted, thus the write never starts.
Any ideas?
I attached a screenshot of the sopc builder with the connections and address offsets, and the modified bfm driver for the testbench.
Richard
1 Reply
    If you show your codes about the DMA transfer, maybe I can help you to find the problem
