17 years agodifferential signal in cyclone 3
hi
i generated 200kHz single ended clock from 2MHz i/p , but i want to take differential output from cyclone 3. is there any option in quartus for that? regards5 Replies
There is no problem, and everything should work, but usually one uses differential signals for high speed signals.
unless you are working in a very noisy environment you won't really benefit from it, and just use up an extra line. - Altera_Forum
Of course not, you can use a differential standard for a DC signals as well.
just for example i explained ,...is there any problem?
why do you need a differential signal for such a slow signal?
Select a differential pin pair and assign a differential I/O standard to the positive pin in the Pin Planner or Assignment Editor. The negative pin is assigned by Quartus automaticly.
