17 years agodifferential signal in cyclone 3
hi i generated 200kHz single ended clock from 2MHz i/p , but i want to take differential output from cyclone 3. is there any option in quartus for that? regards
17 years agoThere is no problem, and everything should work, but usually one uses differential signals for high speed signals.
unless you are working in a very noisy environment you won't really benefit from it, and just use up an extra line.
