14 years agodifferent width dual port ram from VHDL template
Dear all, In my design I have a dual port memory, where the write port is 128x32 configuration and read port is 4096 x 1. I have written the module in the VHDL, but my implementation results in...
14 years ago --- Quote Start --- but why that? If the serializer logic forms a part of the m4k cell, there should be advantage of using the onchip logic rather than generating my own. --- Quote End --- You did not mention the device or memory type in your post. I would recommend using Modelsim to simulate the memory. --- Quote Start --- i still did not find any method how to tell to compiler via tcl commands to instantiate that entity as m4k cell. Whereas when using megawizard on one of the screens it asks you into which memory you want to implement it. Afaik this is quite important as I've read in one of altera documents that m4k memory registers writes on falling edges of write signal. I just hope that I did not understand correctly and this behaviour is only for asynchronous memories, which is not my case --- Quote End --- I have not seen Tcl commands for controlling the RAM inference. Rather, I use the MegaWizard to generate a template, and then copy and edit its internal instantiation of the altsyncram component. Cheers, Dave
