14 years agodifferent width dual port ram from VHDL template
Dear all, In my design I have a dual port memory, where the write port is 128x32 configuration and read port is 4096 x 1. I have written the module in the VHDL, but my implementation results in...
14 years ago --- Quote Start --- As long as the implemented bitwidths are within the supported range of the respective RAM type, there should be not a single RAM cell wasted. At least I didn't observe this in my RAM designs. --- Quote End --- It depends what is meant by "support". I had a design of ram in stratix IV as follows: portA: 16bits x 256 portB: 512bits x 8 resource required: 140 M9Ks !!! if read/write on both ports but reduced to 20 M9Ks if write only/read only. The issue of intrinsic block support is not always visible to the user. Ofcourse if the block is made to support the width there would be no waste. It is when it does not and the tool does not tell.
