14 years agodifferent width dual port ram from VHDL template
Dear all, In my design I have a dual port memory, where the write port is 128x32 configuration and read port is 4096 x 1. I have written the module in the VHDL, but my implementation results in...
14 years ago --- Quote Start --- but why that? If the serializer logic forms a part of the m4k cell, there should be advantage of using the onchip logic rather than generating my own. If you see in the code attached, i have implemented sort of serialization, but it generates quite a lot of logic around the memory cell itself. --- Quote End --- I have never heard of dedicated memory blocks having their own logic. Any logic needed will be borrowed from the fabric in both cases whether you infer by template or use lpm. The question of serialising seems vague to me in its purpose. I assumed you need two different widths so that you can read all 4096 bits in one clock. Otherwise there is no need to make it that wide.
