14 years agoDifferent results on hardware compared to simulator
I'm having trouble when I run my code on the actual Cyclone III FPGA. In the simulator it works fine. I have set up state machines to make sure that clock signals to registers are occurring after ple...
14 years agoI understand that any signal used as the edge to clock a register is considered a clock. I am getting warnings that the launch and latch times between source clock: ale and destination clock: clk are outside legal time range. Ale is basically asynchronous with the main clk. How can I tell it that? I used create_clock not create_generated_clock since ale has nothing to do with the main clk. I guess that is considered another clock domain.
Bidirectional Busses: OK, Got it. Don't use bidirectional busses inside the FPGA to communicate between modules. Just use a data_in and a data_out bus. I will rewrite my code to do this. I am beginning to see improvement with even partial timing constraints set. So far the hardware is working correctly. I will see if it behaves properly as more design changes are made.
