14 years agoDifferent results on hardware compared to simulator
I'm having trouble when I run my code on the actual Cyclone III FPGA. In the simulator it works fine. I have set up state machines to make sure that clock signals to registers are occurring after ple...
14 years agoI have eliminated the latches.
I'm a bit puzzled about your comment about not using tristate nodes inside the design. I am trying to implement bi-directional data busses. Of course at the ports of the device that is required to interface with a multiplexed address/data bus. But inside when communicating with the modules are you suggesting that it would be better to implement it as data_input bus and data_output bus? Keep them separate (which doubles the interface pins for the data between modules). I can do that if you believe that is a recommended better practice. Clock multiplexers are created by the synthesis, I did not code them. Its probably because I have so many different registers being clocked by the main input clock, but I don't really know. When I talked about setting up data and clocking it one cycle later I was not referring to coding it down at the lowest registers. I meant that I have data coming in that is enabled by an external write signal. The rising edge of that write signal should clock the data into an input register. Then internally I need to decode that data (it can be an address). So to give the decode logic time to operate I wait one clock cycle then clock it into the internal register where I need to put it. I assume that you cannot expect to clock data, decode it with comb logic and then clock it into a final register all at the same external clock edge. So thats why I created state machines to sequence the logic in a well defined manner. Am I wrong in this? I wish I had an experienced FPGA designer around. We are a very small startup company and I do all the hardware engineering and just got my first FPGA boards back about 3 weeks ago. I have a design that needs to get shipped by the end of this weekend so I'm up against a real time pressure to figure this out. This is actually the second FPGA design. The first one I did a week ago and got it working but I cannot predict what happens when I make a small change in the logic. I know now that its because I did not do the timing and that affects the fitter results tremendously. So, here I am learning timing.
