14 years agoDifferent results on hardware compared to simulator
I'm having trouble when I run my code on the actual Cyclone III FPGA. In the simulator it works fine. I have set up state machines to make sure that clock signals to registers are occurring after ple...
14 years agoI was able to eliminate the latch warnings. Code running on the hardware is still working illogically (or rather not working).
Is this warning a real concern: Warning (13004): Presettable and clearable registers converted to equivalent circuits with latches. Registers power-up to an undefined state, and DEVCLRn places the registers in an undefined state. I eliminated this warning on a couple of registers at a lower level. Should I pursue this more? I also get a bunch of warnings in the timing analysis of this type: Warning (332060): Node: uart:rs485_port|baud_clk[0] was determined to be a clock but was found without an associated clock assignment. It seems to occur for every signal that is used as an edge trigger to a always_ff block, like this: always_ff @ (posedge reset_n, posedge baud_clk[0]) begin blah,.... end In that particular example the baud_clk is a 4 bit counter that is just being clocked by the main system clock (after it goes through another counter I use for deriving the desired baud rate * 16). Is there a quick and easy way to set up the timing analysis so that it checks things properly?
