14 years agoDifferent results on hardware compared to simulator
I'm having trouble when I run my code on the actual Cyclone III FPGA. In the simulator it works fine. I have set up state machines to make sure that clock signals to registers are occurring after ple...
14 years ago --- Quote Start --- I have not done timing. Since the chip is running at such a slow clock rate (14 MHz, about 70 ns period) --- Quote End --- Try including a minimal .sdc file, eg., here's one I've copied and then edited to reflect your clock, edit the port name for the clock, and then edit the names of the reset and outputs that you do not care about (with regards to meeting clock-to-output delays):
# -----------------------------------------------------------------# Clock# -----------------------------------------------------------------# # 14MHz clock (70ns period)
set clk_period 70
# External clock (internal logic clock)
set clk clkin_14MHz
create_clock -period $clk_period -name $clk
# -----------------------------------------------------------------# Cut timing paths# -----------------------------------------------------------------# # The timing for the I/Os in this design is arbitrary, so cut all# paths to the I/Os, even the ones that are used in the design,# i.e., reset and the LEDs.#
# External asynchronous reset
set_false_path -from -to *
# LED output path
set_false_path -from * -to
The latch warning is also a worry. Fix your logic so that registers are used, not latches. --- Quote Start --- At this point SignalTap would be difficult because I don't have access to the JTAG port without hacking the board (a flaw which I will correct on the board in the future). --- Quote End --- Lesson learned then, eh :) Cheers, Dave
