15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years agoDear Tricky and Daixiwen
Could you check this code for me? When I simulate by waveforms vector of Quartus, at Result_out, the final result is true but I have a lot of result Ex: (-30)x(-6) = 180 but I saw, they have 16, 148, 180. (I attached this waveforms in this message) I don't know this value. Thanks before.
library IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.numeric_std.all;
Entity Multvhdl is
Port (
A,B : In Signed(15 downto 0); --A*B
Result_out : Out Signed(31 downto 0);
CLK : In std_logic);
end Multvhdl;
Architecture structural of Multvhdl is
Signal Multiplicant,Multiplier : Signed(15 downto 0);
Signal Result : Signed(31 downto 0);
Signal CNT : unSigned(3 downto 0);
Signal Sign : unSigned(1 downto 0);
Begin
Process(clk)
Begin
if clk='1' and clk'event then
cnt<=cnt+"1";
sign<="0" & (A(15)xor B(15)); --Check sign of A and B
if cnt="0000" then
Multiplicant<= ABS (A);
Multiplier<= ABS (B);
elsif cnt="0001" then
Result<=Multiplicant*Multiplier;
elsif cnt="0010" then
if sign = "00" then
Result_out<=result;
elsif sign = "01" then
Result_out<= -result;
end if;
cnt<="0000";
end if;
end if;
end process;
end structural;
