15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years ago --- Quote Start --- comment out std_logic_arith and std_logic_unsigned packages. Bring back numeric_std package. Then make remainder and divider signals signed types. You cannot assign a "signed" type to a std_logic_vector. --- Quote End --- Thanks tricky I have a big problem with this code. If A,B> 0, It's OK. But A or B < 0. the result not correct. Could you help me?
library IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.numeric_std.all;
Entity Devide is
Port (
A,B : In Signed(7 downto 0); --A/B
Quotients,Remainder_out : Out Signed(7 downto 0);
CLK : In std_logic);
end Devide;
Architecture structural of Devide is
Signal Remainder,Divider : Signed(7 downto 0);
Signal Result : Signed(7 downto 0);
Signal CNT : unSigned(3 downto 0);
Begin
Process(clk)
Begin
if clk='1' and clk'event then
cnt<=cnt+"1";
if cnt="0000" then
if B="00000000" then
cnt<="0000";
else
Remainder<= A;--ABS (signed(A)); --Remainder = ABS(A)
Divider<= B;--ABS (signed(B)); -- Divider = ABS(B)
end if;
elsif cnt="0001" and Remainder >= Divider then
Result<=Result+1;
Remainder<=Remainder-Divider;
elsif cnt="0010" and Remainder >= Divider then
cnt<="0001";
elsif cnt="0011" then
Quotients<=result;
Remainder_out<=Remainder;
elsif cnt="0100" then
cnt<="0000";
result<="00000000";
end if;
end if;
end process;
end structural;
