Detailed re-configurable PLL data description for Cyclone 10?
I was kind of expecting that you will retreat to a position that is like this. However, everyone who has been following this thread should know how silly it is to rate this information "classified", as I heard from the Arrow application engineers that there are other customers who have problems with the stability of these PLLs especially with low reference frequencies.
Please note that in a different design with a 10CL025, I've had trouble with the PLL running from an 8MHz reference clock; the PLL lost lock every now and then (maybe once every five seconds), despite perfect voltages and low ripple (<15mv) on 2.5V and 1.2V supplies. After I've put an extra 50MHz oscillator into the design and generated all clocks from that, all problems were gone. Note that jitter on the 8MHz clock was under 250ps - just in case the Arrow app engineers have not reported that case. The design was a migration from an EP3C25, where the 8MHz reference clock has worked for years in the field.
The 50MHz solution is not very satisfying, as I have bought FPGAs with PLLs that are supposed to work with reference clocks as low as 5MHz. In other words: Either the calculation(s) that these black-box-megafunctions do are not correct, or these PLLs just don't comply with the datasheets you're providing.
Having over 30 years of experience reading datasheets, I know that things sometimes need to be read "between the lines". I would have loved to calculate the loop filter components myself, as I'd have the chance to verify what's going wrong. After all, the errors in the document that was posted in this thread is showing without a doubt that people who work for Altera/Intel are not free of errors either.
Revealing a full description of these values can help improve the documentation of your products. I don't see how this could be any problem for Intel, other than admitting that you have no exact idea either (which is no problem, as it's not an Intel invention, but acquired from Altera). You should not be afraid of getting this right - it will ultimately improve your product.
kind regards,
Jens
