Navaneeth
3 years agoDesign works in ASE not on FPGA
Hi, Our design works in the ASE simulation environment. But it doesn't work on FPGA. Timing constraints are being met. Please let us know as to what we might be missing / going wrong. Thanks
- 3 years ago
Thanks for the response. The steps to run on FPGA seems to require using AFU, which unfortunately I don't have the resources to.
Is it possible to share a tar.gz file of the Quartus project?
Also, in a previous comment you mentioned you want to view waveform generated in real time on FPGA, you can use Signal Tap Logic Analyzer: https://www.intel.com/content/www/us/en/docs/programmable/683819/21-3/logic-analyzer-introduction.html
If you want to do RTL simulation you can do so as well, here's an example: https://www.intel.com/content/www/us/en/docs/programmable/683870/22-1/quick-start-example-modelsim-with-verilog.html
Nurina
JohnT_Altera
3 years agoHi,
Can you share with us the code and step to duplicate the issue so that we can further look into the issue?
