8 years ago
design simulation
hello
i've done a design using quartus 17.1 pro. but i coudn't simulate this design. i tried to convert it to a VHDL script but i dindn't know how
how can i simulate it or convert it
    I remember having to point Quartus to where my simulator (Modelsim) was installed. Check under Tools->Options->General->EDA Tool Options the path to your simulator. In my case (for ModelSim-Altera): I have next to Modelsim-Altera the path c:\intelFPGA_lite\16.1\modelsim_ase\win32aloem. If this is not set Quartus does not know which program to start to run your simulation.
    I use custom scripts to compile and run my testbenches, so I cannot help you with other flows.
    my problem is i don't know how i simulate it. i've tried with VWF file i put all my variables but when i launch the simulation an error message appears "ModelSim executable not found."
    I have a few more questions, please elaborate on your problem: You say you can't simulate, how do you know, does your simulator (which?) not start, does the program start but won't run simulation? How do you start your simulator program? From Quartus? If so, can you see any errors in Quartus? Where I don't mean compile errors but errors regarding the start of the simulator you use. If not how do you start it?
    [edit] I assume you have the correct libraries to run pll sim?[/edit]
    no i can't simulate using vwf and it isn't simple design it contains ip's like pll .transceiver ..
    Are you able to simulate the design using VWF? what problem are you facing elaborate more.
    For design are you using QSYS or Mega-wizard or simple design without any IP's?
    Anand Raj Shankar
    for simulator i use VWF file or i want to convert my design to vhdl code to use modelsim but i couldn't
    hi i don't have an error message my design compiles correctly
    Which si ulator are you using and how do you start it?
    1.Attache the ERROR message/Log file.
    2.Which IP's are used in the design?
    Anand Raj Shankar
