8 years agodesign simulation
hello i've done a design using quartus 17.1 pro. but i coudn't simulate this design. i tried to convert it to a VHDL script but i dindn't know how how can i simulate it or convert it
8 years agoI have a few more questions, please elaborate on your problem: You say you can't simulate, how do you know, does your simulator (which?) not start, does the program start but won't run simulation? How do you start your simulator program? From Quartus? If so, can you see any errors in Quartus? Where I don't mean compile errors but errors regarding the start of the simulator you use. If not how do you start it?
[edit] I assume you have the correct libraries to run pll sim?[/edit]
