16 years agoDesign portability on a cyclone
Good morning, I've got a HDL design which run in RTL simulation. This design run in gate level simulation with time modelisation on a stratix II or an arria II. Howerver, it doesn't work on ...
16 years agoI found, that there's exactly one dangerous warning in the Cyclone III report:
--- Quote Start --- Warning: Synthesized away the following node(s): Warning: Synthesized away the following RAM node(s): Warning (14320): Synthesized away node "FDCT:U_FDCT|MDCT:U_MDCT|ROME:\G_ROM_ST1:0:U1_ROME|altsyncram:Mux11_rtl_15|altsyncram_0hv:auto_generated|ram_block1a0" --- Quote End --- It's originated from an instance of rome.vhd. By changing the table definion in rome.vhd from constant rom : ROM_TYPE := to signal rom : ROM_TYPE := the above warning vanished and the ROM implementation was changed from Mux11_rtl_15 to rom_rtl_15. I didn't set up the ModelSim simulation, but I hope, the problem can be solved this way.
