16 years agoDesign portability on a cyclone
Good morning, I've got a HDL design which run in RTL simulation. This design run in gate level simulation with time modelisation on a stratix II or an arria II. Howerver, it doesn't work on ...
16 years ago --- Quote Start --- Hi, I already tried with the new quartus version 9.1. However it doesn't work. If you have an idea it would be great. In anyway, thank you. --- Quote End --- Hi actris, which versions did you try up to know ? 9.1 and 9.0 ? Maybe you should try an older one. I will try to setup your project in my environment, but this take some time. Kind regards GPK
