10 years agoDelaying output of a module to close timing
I've created a module where two numbers are multiplied and the output is provided in a number of clock cycles. However, the output of the module (pdt1_out) is failing timing in that the setup slack ...
10 years agokaz and ak6dn:
Thank you so much for your help; this is much appreciated! 1. To resolve the timing issues, I had to create an instance of the multiplier using the megawizard IP. The inputs were both 64 bit, and the output was 128 bits. The IP was set to have a pipeline of 4 clock cycles. 2. The multicycle path constraint works well to remove some timing issues. The description given by ak6dn is good and I've learned much from this. Apparently the recommended HDL coding style (page 12-4, https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts_qii5v1.pdf) for an inferred multiplier does not work well in all situations (particularly for a high clock frequency) and cannot be easily extended beyond 2 clock cycles. So once again, thank you. The timing issue is resolved. By the way, the regs within the unsigned_mult64 module should be unsigned rather than signed.
